本文档为《磁保持WIFI计量插座》 [https://oshwhub.com/oldfox126/ci-bao-chi-wifi-ji-liang-cha-zuo](https://oshwhub.com/oldfox126/ci-bao-chi-wifi-ji-liang-cha-zuo) 项目配套的手机APP设置参数
设置方法参考:[https://oshwhub.com/article/ci-bao-chi-WIFIzhi-neng-cha-zuo-pei-tao-de-shou-ji-APPan-zhuang-ji-she-zhi-shuo-ming](https://oshwhub.com/article/ci-bao-chi-WIFIzhi-neng-cha-zuo-pei-tao-de-shou-ji-APPan-zhuang-ji-she-zhi-shuo-ming)
可以参考上面的方法设置好MQTT服务器和仪表盘,**装置参数就不要直接抄了**,跟上面的有所不同。 具体的装置参数在本文档后面。 全部设置好以后,界面类似如下:![20220910232256.jpg](//image.lceda.cn/pullimage/hoNucXgFJ43eXDiW4cmxNTfqqQYp1DmwqVYfIE8q.jpeg) ## 装置参数: 1.类型:Toggle Name:开关 MQTT enable:打开 MQTT connection:选择 broker-cn.emqx.io Subscribe to topic: **oldfox126/esp12s/hlw/s4QEJYlo**/stat/relay Qos(Qos for subscribe/Qos for publish):2 Topic for publish: **oldfox126/esp12s/hlw/s4QEJYlo**/relay/in - - - 2.类型:Gauge Name:计时器 Min:0 Max:100 step:1 default:50 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/stat/countdown Qos:2 publish:**oldfox126/esp12s/hlw/s4QEJYlo**/countdown/in - - - 3.类型:Toggle Name:调试 MQTT enable:打开 MQTT connection:选择 broker-cn.emqx.io Subscribe to topic: **oldfox126/esp12s/hlw/s4QEJYlo**/debug Qos(Qos for subscribe/Qos for publish):2 Topic for publish: **oldfox126/esp12s/hlw/s4QEJYlo**/debug - - - 4.类型:文本 Name:当前时间 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe: **oldfox126/esp12s/hlw/s4QEJYlo**/stat/time Qos:0 publish:无 - - - 5.类型:Toggle Name:定时器 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/stat/timer Qos:2 publish:**oldfox126/esp12s/hlw/s4QEJYlo**/timer/start - - - 6.类型:Date & Time Name:设置定时开 Format date & time: HH::mm MQTT enable:打开 connection:broker-cn.emqx.io Subscribe and publish:**oldfox126/esp12s/hlw/s4QEJYlo**/timer/starttime Qos:2 - - - 7.类型:Date & Time Name:设置定时关 Format date & time: HH::mm MQTT enable:打开 connection:broker-cn.emqx.io Subscribe and publish:**oldfox126/esp12s/hlw/s4QEJYlo**/timer/endtime Qos:2 - - - 8.类型:Text Name:定时开 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/stat/starttime Qos:0 publish:无 - - - 9.类型:Text Name:定时关 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/stat/endtime Qos:0 publish:无 - - - 10.类型:Text Name:电压/电流/功率/电量 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/stat/power Qos:2 publish:无 - - - 11.类型:Text Name:当前固件版本 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/stat/ver Qos:0 publish:无 - - - 12.类型:Toggle Name:升级固件 MQTT enable:打开 connection:broker-cn.emqx.io Subscribe:**oldfox126/esp12s/hlw/s4QEJYlo**/ota Qos:2 publish:**oldfox126/esp12s/hlw/s4QEJYlo**/ota Confirm send:打开 Message*:确定要进行在线升级? (完) PS:******以上所有设置中的黑体 oldfox126/esp12s/hlw/s4QEJYlo 都应该替换成你自己的topic参数******
