CompatibleMV-OV2640
CompatibleMV-OV2640
1.6k
兼容openmv4的摄像头模块
简介:兼容openmv4的摄像头模块
创建时间:2024-08-05 22:29:44更新时间:2024-08-06 14:32:07
<div>一个可用于OpenMV4的OV2640的模块,将FPC模组转接到OpenMV4的BTB座子。</div> <p>&nbsp;</p> <div>摄像头我用的是<a href="https://m.tb.cn/h.gkDQKAOUux5XX3U?tk=fmPn3W9kW5P">https://m.tb.cn/h.gkDQKAOUux5XX3U?tk=fmPn3W9kW5P</a>,M12的应该都能锁上螺丝</div> <div>BTB连接器我用的是<a href="https://m.tb.cn/h.gkD9MfOiVl2YqBc?tk=uAQm3W9l4WF">https://m.tb.cn/h.gkD9MfOiVl2YqBc?tk=uAQm3W9l4WF</a>, 选择DF12NB(3.0)-36DP-0.5V</div> <div>&nbsp;</div> <div>摄像头实测需要翻转,例子如下</div> <div>```python3</div> <div>import sensor</div> <div>import time</div> <div>&nbsp;</div> <div>sensor.reset()&nbsp; # Reset and initialize the sensor.</div> <div>sensor.set_pixformat(sensor.RGB565)&nbsp; # Set pixel format to RGB565 (or GRAYSCALE)</div> <div>sensor.set_framesize(sensor.QVGA)&nbsp; # Set frame size to QVGA (320x240)</div> <div>sensor.set_hmirror(True)</div> <div>sensor.set_vflip(True)</div> <div>sensor.skip_frames(time=2000)&nbsp; # Wait for settings take effect.</div> <div>clock = time.clock()&nbsp; # Create a clock object to track the FPS.</div> <div>&nbsp;</div> <div>while True:</div> <div>&nbsp; &nbsp; clock.tick()&nbsp; # Update the FPS clock.</div> <div>&nbsp; &nbsp; img = sensor.snapshot()&nbsp; # Take a picture and return the image.</div> <div>&nbsp; &nbsp; print(clock.fps())&nbsp; # Note: OpenMV Cam runs about half as fast when connected</div> <div>&nbsp; &nbsp; # to the IDE. The FPS should increase once disconnected.</div> <p>```</p> <p>&nbsp;</p> <p>效果如图,说实话不是很好,帧率也不是很高,图一乐(</p> <p><img src="//image.lceda.cn/oshwhub/03a0b9170c9e4eedba7d5803f25f9925.jpg" alt="" width="1800" height="2559" /></p>
