YBA-AMS_Remix
3D打印用单通道耗材料架控制板
简介:3D打印用单通道耗材料架控制板开源协议
:CC BY-NC-SA 3.0
修改自YBA-AMS
Modified from YBA-AMS。
⚠请注意,当前版本虽能满足AMS lite供电能力,但功耗较高,请自行斟酌。下一版本PCB将会兼容MP1584解决LDO功耗问题,可等待解决后再制作。
⚠ Pls note that although current version can be supplied by AMS lite connector, but it's power consumption is quite high. The next version will be compatible with MP1584 to solve it, you can wait for a short time (hope so).
推荐工艺:
- 板厚:1.6mm
- 最小孔径/外径:0.3mm(免费)(外径0.4/0.45)
- 板上加标志:加序列号二维码
- 二维码尺寸:8*8mm
- 二维码位置:指定位置添加
修改内容:
- 改4通道为1通道,方便耗材干燥箱内单独控制。
- 改USBC/DC供电为AMS lite接口供电。
- DRV8833由成品板改焊接,优化PCB面积。
- 手动控制开关由接线改焊接,直接固定在耗材干燥箱。
可以同时看到工程中包含开关小板与电机小板,是为了优化干燥箱内走线而设计。需要配合下一个版本的料架使用,您可以在makerworld上查看[YBA-AMS(Remix)]的更新进度。
Modified note:
- From 4 channels to 1 channel, to control the sole holder in one case.
- From USB-C/DC power supply to AMS lite.
- From finished DRV8833 board to soldered DRV8833.
- From cable connected switch to soldered switch on board.
You can find 开关小板 and 电机小板 in this project, it's designed for the cable managment in case. They should be used w/ the next version of spool holder, you can kindly check the update status of [YBA-AMS(Remix)] in makerworld.
